RCU Forums - View Single Post - Epoxy or PolyC for glassing
Old 08-02-2010 | 01:00 PM
  #36
BobH
Default RE: Epoxy or PolyC for glassing
tfarmer, If you use a small roller as I suggested in my last post you don't hafta worry. If you can paint a wall with a roller then you can apply the Epoxy to the wing. The LE and TE are put down using a small acid brush or similar object.
