RCU Forums - View Single Post - First build, third plane. Looking for recommendations (must be scale)
Old 08-03-2010 | 07:34 AM
jeffski
Default RE: First build, third plane. Looking for recommendations (must be scale)
<p class="MsoNormal" style="margin: 0cm 0cm 0pt"><font size="3" face="Calibri">The magnattila,puppeteer,legionnaire &amp; baronette date from the early&lsquo;80s (SE5a 1988) back then 4-strokes where VERY expensive ,so a 2-stroke was the common choice for power .The magnattia (also a excellent first build ww1 model) and pup have been completely updated, not certin if the se5 has been though .I had my pup for twenty years and it had 2 and 4 stroke engines, only difference ....was the noise !! </font></p><p class="MsoNormal" style="margin: 0cm 0cm 0pt"><font size="3" face="Calibri">The only part of the build that might give you problems is the <span style="mso-spacerun: yes"></span>construction <span style="mso-spacerun: yes"></span>of the ailerons , but as Abu pointed out, you only have to ask !!</font></p><p class="MsoNormal" style="margin: 0cm 0cm 0pt"><o><font size="3" face="Calibri"></font></o></p>
