ORIGINAL: BoomerangGuy
Hi guys. If I needed to how could I extend the MPI lead to reach the turbine. Also can I use normal servo extentions for the rpm sensor? Cheers. George
Yes you can with servo extensions on RPM and Temp sensors
not sure what MPI lead is..
, but basically you could solder the length required on to any of these cables
hope this helps,
Barry
