RE: POST A PIC OF YOUR DRIFTER THREAD!!!!!!!!!
Yeah I was pre-warned about that when I started building mine.But I ended up not tightening it enough and had some problems until I figured out what it was. Iused a spool in back which is nice, maybe you should look into getting that for the rear and move the good diff to the front. Remember you need 42mm drive shafts if you use the Spool though.
