RCU Forums - View Single Post - Tail Wheel Idea ?
Old 08-03-2010 | 02:06 PM
ro347
My Feedback: (13)
Default RE: Tail Wheel Idea ?
ORIGINAL: RCKen
Install a Sullivan Tailwheel. I mounts on the bottom of the fuselage and has a spring that extends out to the rudder and inserts into the wood on the bottom of the rudder. This will give you a steering tailwheel.
These are the tailwheels that I prefer because the spring isolates the rudder from the tailwheel in case the wheel is jammed or jerked to the sides. It prevents damage to the rudder.
http://www3.towerhobbies.com/cgi-bin...&I=LXFV47&P=ML
Ken</p>
Ditto! I personally dont like the tailwheels which glue into the rudder. Feel as if its something you'll have to fix later!
