RCU Forums - View Single Post - Glue
Thread: Glue
Old 08-03-2010 | 04:23 PM
OzMo's Avatar
OzMo
Default RE: Glue
Acetone fumes are none to swift either.
Best used outside or at least when the wife is not home
Repeated applications work best when needed. I have UN-built a wing half this way.
Funny, that was the same day I discovered the building table had warped
I used it on another wing I bought and had to rebuild. The Ca gets rubbery the u scan scrape it off. In thick glued areas reaplication is needed. An absorbent material(rag) works well here too.
