RCU Forums - View Single Post - Sanwa/Aitronics SD-6G Unofficial Thread
Old 08-04-2010 | 02:32 PM
bigedmustafa's Avatar
bigedmustafa
Default RE: Sanwa/Aitronics SD-6G Unofficial Thread
The SD-6G is finally up on Hobby People's web site for your pre-ordering pleasure, albeit at a $199.99 price tag:
http://www.hobbypeople.net/gallery/751660.asp
Hobby People is currently showing a street date of August 16, 2010 for the radio, but that can certainly slide to a later date easily enough. It's nice to see that rechargable batteries and the wall charger will be included.
Key Features:
10-Model Memory
Advanced Airplane and Heli Software
3 Flight Modes (Heli and Air)
P-Mixes
3-Axis Dual Rate and Expo
5-Point Throttle Curve (Heli and Air)
Gyro Switch (Heli)
Advanced Swashplate CCPM Mix (2 and 3 sx)
Advanced Swashplate Leveling (Heli)
Servo Monitor
Throttle/Engine Cut Switch
Trainer Compatible with SD-5G and SD-10G
Adjustable Gimbal Spring Tension
Advanced Aircraft Mixes
Direct Select – Model Select Buttons
Program Features (Common for Both Heli and Air):
Model Naming
Model Select
Model "Direct Select"
Data Reset
Data Copy
Trainer System (Compatible with SD-5G/10G)
Throttle Cut
Wing/Swash Type
Dual Rates (3 axis) (Common or Individual for Flight Modes)
Exponential (3 axis) (Common or Individual for Flight Modes)
3 Flight Modes
Individual or Common Trims
Program Mixes (2)
Servo Reverse
Sub Trim
EPA
Servo Monitor
Stop Watch
Airplane Functions:
Wing Type
Aileron Differential
Flaperon Mix
Flap-Elevator Mix
Dual Elevator Mix
Ailvator
V-Tail
Delta
Program Mixes (2)
(Note: Curves, D/R, EPA, All Mixes can be individual for Flight Modes)
Helicopter Functions
CCPM/Swash Type (2 and 3 servo swash plates)
5-Point Pitch Curve
Revo-Mix
Gyro Control
EPA for Individual Swash Servo (swash leveling)
3-Axis EPA post-mix
Swash Mix Control
Throttle Trim Inhibit for Aerobatic Flight Mode
Program Mixes (2)
(Note: Curves, Gyro, D/R, EPA, All Mixes can be individual for Flight Modes)
RX-600
We've paired the SD-6G with the spectacular small-size full-range RX600 6-channel receiver. This receiver is compatible with all Sanwa 2.4GHz aircraft radios. It uses only two little antennas on extensions, so you can place them in the best spot for full-range performance. And at a weight of under 12 grams with case, it'll fit in just about every application. But, if it doesn't, Airtronics offers a wide selection of receivers from 5 gram 6-channel park flyer receivers to affordable 5-channel full-range receivers, Airtronics has the right receiver for your application.
Specifications:
6-channel operation with RX600 receiver
FHSS-1 Frequency-Hopping Spread-Spectrum
2.4GHz band
Programming Features: Aircraft AND Helicopter
10-Model Memory
Mode 2
TX Battery: 6 AA 1200mAh Ni-MH
Includes:
SD-6G Transmitter
RX600 Full-Range Receiver
6 AA's (1200mAh Ni-MH Rechargable)
Overnight Dual-Output Charger
Detailed Instruction Manual
1-Year Warranty
