RCU Forums - View Single Post - Radio problems
Old 08-04-2010 | 10:01 PM
shannah
Default RE: Radio problems
Hi Bill
Does your regulator plug directly into your receiver? If so, check the connector from the smartfly regulator which plugs into your receiver. This evening I was out flying and on my first flight the plane just didn't "feel" right. It dropped a wing big time on landing as well. I instantly thought of you. I was poking around and noticed that the connector from the smartfly regulator was wiggling on the receiver. I tried to push it in more but it didn't seem to help. I think the connection wasn't very good. So I put an extension cable on it and had the extension cable plugged to the receiver and I wrapped the connection from the reg to the extension cable in tape. I don't like the connector supplied with the regulator.
After my fix I never felt the same issues and it was rock solid. This might explain why I felt that some flights were great where
as other flights seemed to have some issues.
steve
