Preflight check list
1: Transmitter on
2: Receiver on
3: Check Batteries
4: Range check
5: Check Servos and make sure everything is right!
6: Check Servos for correct direction! Right , Left ect.
7: Make sure prop has no damage and Tight!
8: Make sure Wheels still on and set screws are tight!
9: Fuel
10:Ignition
11:Start it up and make sure the engine is properly tuned!
Make sure that the engine is off before you start the shut down procedure.
1: Receiver first off
2: Transmitter second off
3: Check batteries
4: Go through the check list again if you are going to fly again!
