RCU Forums - View Single Post - Air Fill Question
Old 08-05-2010 | 12:14 PM
Harley Condra
Default RE: Air Fill Question
With the BVM Air Fill Valve, you can insert a length of air line into the hole in the valve.....use an extra air fill valve in the chuck of the compressor, or a BVM Air Fill Chuck...P/N BVM2192.
Cut a slight bevel on the end of the hose, and do not insert it more than 3/16" into the fill valve..Use Caution....there is a very small "Duck Bill One Way Check Valve" inside that could be damaged if the tube is inserted too deep.
ID:	1478444   Click image for larger version
