RCU Forums - View Single Post - Avistar Arrived
Old 08-05-2010 | 04:08 PM
FlyingGatsby
Default RE: Avistar Arrived
Okay guys, I've encountered another problem :|
The Futaba S3001 servo has a little rubber guard, to protect the servo wire as it comes out of the case, problem is, this guard makes it so the servo wire doesn't fit in the pre cut pocket. I can't cut the pocket bigger, because if I did, I would cut into the root for the wing Joiner.
What should I do? I circled the rubber guard in the pic, it's a faint circle, but you can see it.
Pic: http://s902.photobucket.com/albums/a...ent=Servo2.jpg
