RE: Radio problems
Hi Steve
Yes I was using a Smartfly regulator plugged directly into the receiver when I first started having problems but I replaced it with another
regulator before I crashed. I'm using the Smartfly in my test plane now. I havn't had any problems so far but I will check the connector.
I believe now that my problem was interrmittent power failures. I have two receiver batterys that I use. One has a connector that doesn't
plug in as tight as the other. I didn't tape it. STUPID. I think I only had the problems when I used this battery.
Thanks everybody for taking the time to help me with this problem.
Bill
