RE: Fliteskin Ta-152 H1
I have two Holman Doras, one with foam wing and the other is a new style offered as a complete built up wing. I can say from the builds that I've done that the foam wing is much heavier then the wood. Incorporating a jig type system into the wing will prevent the twist complications in the build. On the newer wing design of wood, I can say the build went much faster than the foam wing! I have a forum on the wood wing also and if you check out the dates, you can verify this.
