RCU Forums - View Single Post - Avistar Arrived
Old 08-06-2010 | 05:52 PM
  #42
rlipsett
Default RE: Avistar Arrived
regarding cutting the hole for the servo. I usually only make a small v notch to allow the wire to sneak through. second concerning mounting blocks. Remember you need enough meat for the mounting screws to bite into. If the screws are only going into a thin balsa sheet they will pull out and then you will have a mess on your hands while flying. Also harden the servo mount holes with thin ca
