RCU Forums - View Single Post - Avistar Arrived
Old 08-06-2010 | 05:52 PM
  #43
FlyingGatsby
Default RE: Avistar Arrived
ORIGINAL: rgm762
batteries not charged
tx/rx not bound
servos not plugged in correctly, if your using extnesions or y harness
not plugged in the right channel on the rx
Batteries not charged, is the most likely for me right now. Because I double checked every connection, and it's an FM radio.
Also, how do you fuel proof the firewall, and reinfornce it?
@rlipsett
I've done everything on your list
The problem is, since I have the rubber boot on the servo, I have to glue the halves together, and the mount on at the same time. I can't get the servo in if the halves are together.
Also, when it says 4drops of CA on the hinge, is it 2 on the top of the hinge and 2 on the bottom? Or will the CA just spread around the hinge by itself.
And will a sewing pin work, instead of a t pin?
