RCU Forums - View Single Post - Avistar Arrived
Old 08-06-2010 | 09:14 PM
  #55
FlyingGatsby
Default RE: Avistar Arrived
ORIGINAL: Tom Nied
The loop part of the question mark gets pretty big, but when done right you should be able to tilt the wire end in and rotate the servo into the position. Remember, you have the servo mount rails on the outside that raises the servo a bit. I agree, it seems weird, but I've done this on a number of models including my two Avistars and it takes a bit of perseverance and determination to get it opened enough that you can rotate that servo into position. None of this should affect structural integrity of the wing.
So you're saying I should do something like this, enlarging the notch for the servo wire: [img]file:///C:/DOCUME~1/HAITRI~1.HAI/LOCALS~1/Temp/moz-screenshot.png[/img]http://s902.photobucket.com/albums/ac227/PurpleGatsby/?action=view&current=ServoPocket.jpg
But wouldn't I have to enlarge it a lot? Since the servo has a rubber boot. The pocket doesn't have much space for the servo to move back and forth either, more sanding ahead?
