RCU Forums - View Single Post - engine issue
Thread: engine issue
Old 08-06-2010 | 11:36 PM
Bluethunder3320's Avatar
Bluethunder3320
Default RE: engine issue
also i forgot to specify the foam soap is to see is its leaking, so if it bubbles as the motor cranks then there is a leak and there is your problem. if its hard to tell, put your finger over the glow plug hole and try to tell if there is high pressure, likely you will not be able to seal it with a finger.
