You're welcome Dave, but really, you would want to try it first. And when you do get some results, please report back.
Besides Bob and me, I don't know if anyone else has their pattern models flying yet. There's a ton of flying info on the sport thread for the SAP with sport models on mufflers and small props, but very little flying experience on pattern models on piped set-ups with pattern sized props.
I dabbled a bit with the EF Extra/SAP/pipe. This plane is much larger, heavier and draggier than anything pattern related. I found that a pattern prop on that plane was not as effective as a larger diameter lower pitch like a 19x8....allowed higher spool up and better thrust (but noisier too)
Matt,
Reality has imposed itself on my plans to build the Pentathlon Evo this summer.
But when I do finally start on it I plan to keep it as light as possible, hopefully a bit under 10 lbs but more than likely a bit over because of the pipe tunnel.
PS I have a package with the props inside ready to mail, just PM your addy.
