RE: Avistar Arrived
It might, I just read about it, you must know the amperage needed to work each servo or any other electric device attached to the receiver.
"Our tests show that ONE JR 8717 servo draws 2.2 amps under load. A system using just 3 of these servos (not counting tail servo, receiver or gyro) would draw more than 6.5 amps during flight. When one adds in the draw of the tail servo, receiver and gyro, the load is much more than the 5 amp continuous..."
Took it from Castle creations.
You may try with other receiver.
