RCU Forums - View Single Post - Senior Telemaster "short" kit build
Old 08-07-2010 | 09:32 PM
vmsguy
Default RE: Senior Telemaster
Date: October 6, 2007
Today I went flying. I took the LT40 on it's maiden flight with it's new motor/prop. It flew great! And I even got a good amount of stick time.
But onto this bird. I contacted Lazerworks and they told me the 3/16" rib was to be laminated with a 1/8" rib. This is to be installed where the aileron will be cut. The extra thickness provides area on both the wing and the detached aileron. When I get to that point in the construction, I hopefully will remember to photograph and document it.
On my wing, I plan to use the plywood ribs for the first three ribs. Then, the fourth rib will be the extra thick rib. I plan on sheeting the bottom of the wing between ribs one and two. I also plan on sheeting over ribs one, two, and three on the top. Before I can install the plywood ribs, I need to cut 1/8" off these pieces before I can put them in place.
So I went on to place the 1/8" ribs. I used q-tips to make sure there was glue at every joint, and to wipe access glue away. I hope to use transparent monocoat on this plane, so all my glue work has to be good.
I finished installing all the 1/8" ribs. Now, I can only install the extra thick rib, then I need to stop. I need to cut the plywood ribs for the sheeting. I am planning on buying a band-saw this upcoming pay-day. I can cut the ribs after I have it.
Picture 1: Laminating the 3/16" and 1/8" ribs together.
Picture 2: Laminating the 3/16" and 1/8" ribs together.
Picture 3: The wing plan.
Picture 4: The 1/8" ribs put in place.
ID:	1479761   Click image for larger version
ID:	1479762   Click image for larger version
ID:	1479763   Click image for larger version
