RCU Forums - View Single Post - Senior Telemaster "short" kit build
Old 08-07-2010 | 10:08 PM
vmsguy
Default RE: Senior Telemaster
Date: November 13, 2007
I got a little time to work on my plane tonight. Yardwork needing to be done before snowfall took precedence this weekend.
Not too much work done tonight. I wanted to reinforce the plywood reinforcement pieces. I cut pieces of 1/16" ply to fit in the holes of ribs 1 thru 3. Then drilled a hole in them. The hole I drilled was larger than the 1/2" hole for the joiner tube holes. These fillers weren't for reinforceing the hole, they were to provide extra glue surface area.
The process was pretty straight forward. I cut six pieces, then fit each piece into the rib. I then traced the holes onto the filler pieces. I drilled the holes and glued the filler pieces onto the ribs.
Once the glue dries, I can continue. Next step, the shear webbing, then sheeting the top of the wing.
Picture 1: Filler pieces temporarily in place in wing ribs.
Picture 2: Filler pieces temporarily in place in wing ribs.
Picture 3: Hole location traced onto filler pieces.
Picture 4: Filler pieces glued in place.
ID:	1479862   Click image for larger version
ID:	1479863   Click image for larger version
ID:	1479864   Click image for larger version
