RE: Himax 6330-F3A Pattern Motor
Hi
I saved some weight with a new undercarriage (bolly but zn is also lighter) change every screw that you can with alu. screws cut the one to a minimum that you cant change also take a closer look at you rx. battery .... cut the el.wires that can be shorten...
dont know any thing off the prop you mention
