RE: Himax 6330-F3A Pattern Motor
Padelis, I suggest, based on the difficulty and length of your routine, that you fly always use a timer to monitor the length of each flight. Also monitor the post flght temps and mah of your batteries. BTW, which batteries are you flying? One more question. What is the total weight of the plane with the batteries attached? It appears your repairs added approx 6 ounces. Based on the weight limit of 2.2 kilos, you may be forced to run smaller batteries. The routine you mentioned above, at first glance, very similiar to our 2011-2012 proposed Short Master's program. Thanks and I encourage you to find other ways to save weight.__Everette
