RE: Himax 6330-F3A Pattern Motor
i ll try to do my best for the weight thats the reason that i am looking for the props weight
My plane with 2x 9650 elevators 2 x 9152 ailerons 1x 9151 rudder motor 6330 (with spinner, prop[apc] but without cut the wires), CC HV 80 (without cut the wires), receiver extension cables are 3970gr
i need 15gr for digiswitch , 1000gr for batteries, and 50gr for rx battery so the total weight are 5035 if i can save 40gr to 50gr from prop and 20gr from wires i thing its ok
I have decide to use ZIPPY Flightmax 4000mAh 5S1P 20C batteries from HC cause none else have similar batteries with similar weight. (499gr including wire, plug & shrink wrap)
If the p11 need 3200 to 3800 mah in windy day i believe that with our program need lower than 3000 mah
Thanks for your encourage
Padelis
