RE: BUSA D-VII BUILD @ EAA 2010
Thanks for the comments and you are correct, Rudolph Starks mount. I have a G38 in mine as well along with the spring starter. THis engine works perfectly all of the time I love it except I feel it is a little underpowered. Prop is important. I have settled on a 19-6 Xoar.
This aircraft has been flying now for 4 seasons and has many awards and trophies. Qualifying for scale masters last year.
You will enjoy your plane. One tip, I would replace the Axel with 1/4" wire. You will be glad you did. My stock wire bent easily until replaced. This is easier done initially.
