RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 08-09-2010 | 06:21 AM
  #255
airborne2.4
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: JOHNS3D
ORIGINAL: a1pcfixer
ORIGINAL: airborne2.4
Do you think the DLE 20cc would work well with this for 3D?
http://www.aero-works.net/store/detail.aspx?ID=75
Still a wee bit overkill, but better suited to THAT particular model, would be this....
[link=http://www.valleyviewrc.com/JBA%2015cc%20Gas%20Engine.htm]JBA J15G 15cc gas engines.....[/link]
it depends, if you look the specs of the Edge will find that the wing area and fuselage is almost the same as a .60-90 airplane, thats why i think a DLE20 can be amazing for the AW Edge, of course with a good propeller will def. make some crazy 3D.
Hhhmmm the specs of the 46-61 Edge 540T and the 60-90 Extra 300 are pretty much the same, thats what I'm looking at. The weight of the DLE 20cc and the JBA J15G 15cc are pretty much the same too. What am I missing here?
Thanks for the feedback
Airborne
