RE: Saito FG-30 gas troubles
The engine is better suited to a scale or general sport plane and is generally not suited well for 3D for it is too heavy for the power output.
The pump in the Walbro has a return spring. The carb gets its impulse for the pump from the intake manifold vacuum itself and then has a spring return. There is also a regulator on the side of the carb.
