RCU Forums - View Single Post - detecting peak engine temp
Old 08-09-2010 | 01:55 PM
  #51
a1pcfixer's Avatar
a1pcfixer
My Feedback: (7)
Default RE: detecting peak engine temp
ORIGINAL: RTK
I have been running on board temp monitors for over 5 years now, I know just about where every manufacturers engines will run when tuned properly. Some are higher than others some are lower. I would never push ''some'' of the chinese engines to higher temps.
Out of curiosity, what numbers might you have for;
DL50?
DA-50r?
I just dug up an older version of Eagle Tree Systems flight data recorder I bought when they first came out. I installed the temp sensor in the upper most fins of my DA-50r, and am waiting till the weekend to run it. So, I'm curious as to what temps I should see.
