Alcohol is just fine and my guess would be it had been run then boxed. The castor oil gums up and freezes up parts. Before you do anything you should use your covering heat gun or your wife's hair dryer and heat it up and get everything freed up. The fuel is just alcohol and oil with some nitro so just plain old alcohol isn't going to harm anything. Heat is your friend when you have a gummed up engine.
