RE: Saito FG-30 gas troubles
Also, fitted to the saito fg-30 gas a smoke sytem using a perry pump, it works but smoke is not too thick, fitted the injector to the blaked, hole on the stock silencer, Ibelive is just the 180 glow one with the backpressure niple blanked off, shall I do an other hole on the actual manifold close to the cylinder head?to fit the injector??, and which fuel tube should I use, tygon one is melting down!!.
Temporally Ifitted a very short piece of glowfuel tube (silicone)next to the exhaust, which Igave a bath on water with sugar and coke,to protect it from the diesel fuel Im using for smoke. which tube will tolerate diesel and high temps???
Many thanks!!
