RCU Forums - View Single Post - Electronic ignition problem
Old 08-09-2010 | 08:16 PM
Truckracer
My Feedback: (19)
Default RE: Electronic ignition problem
ORIGINAL: Mrtazmaned
[font=''Verdana''][/font][font=''Verdana'']I have a zenoah 445 with a conversion done by RC IGNITION. The first ignition failed quickly and was replaced at no charge by Ralph. I'm now getting back to the plane (Smith Mini-plane bipe) scaled to 33%. The initial ignition caused an awful lot of RF, causing the radio to go spaz. With the 2nd ignition, the wires were shielded to minimize this problem.
Started this motor today and the radio went wacko, not being able to control any surface. Shut off the transmitter and ran the motor using manual throttle. The wires to the plugs were ''HOT'', and reaching for the throttle arm resulted in a fairly perky shock!!!
If anyone has any advice that will help me eliminate this RF feedback please feel free to jump in. I have moved all batteries far from the engine, no metal linkage goes from the engine compartment to the internal fuselage The ignition battery is close to the reciever, don't know if this could cause a problem...
HELP...This is a sport plane and I would like to get it into the air...[/font]
If you got a shock from the plug leads, the metal caps were not pushed far enough onto the plugs to complete the ground connection. Installed correctly, the metal cap will cover the hex part of the plug completely. Same problem causes your RFI problem ..... push caps on far enough ... problem should be gone. This is operator error, not an RCIGN problem.
