RE: SH .18 in Volcano S30
only way you loose pinch is when there is excessive heat...(to lean or long full throttle runs while still tuning)..
only other is the build of different cylinder makers,and the odds of that are slim but happens...
also some differ about this after each run leave the piston at the bottom....
I have about 10 good years on buying and rebuilding any engine on this....
