RCU Forums - View Single Post - 72 mhz antenna inside fuselage?
Old 08-09-2010 | 11:00 PM
malthepal
Default 72 mhz antenna inside fuselage?
Im prepping a friends top flite P-40 and to keep the scale look, I want to put the antenna wire inside the fuselage. Can I put this wire inside a plastic pushrod tube glued inside the fuselage or would it be better to get the antenna outside the fuselage?
