ORIGINAL: hakmazter
Think Mini Fusion.......
The answer is balance. We engineer cars to handle on the track. There is a reason why everyone loves how the 1/8 fusion handles.
However, I will double check on the plastic rtr version because I think that if a person flips the motor mount 180 degrees, then the motor will be on the servo side all lined up perfectly and you could run a regular lipo on the other side.
If that is an easy mod, we will truly have the ultimate in versatility.
The pics you posted in the Caster forum show the RTR version use regular non saddle packs .
