RE: Help with JBA 120 2-stroke (ringed)
3,5-4 turns of HSN is not normal.It seems your carb. has some blocking.I recommend you to remove the carb.and disassamble fully.Check for the dirt particles especially on the spray nozzle inlets.
Hard start means unproper priming.Also hard turns means possible choke by fuel.I guess your tank is siphoning into engine.
