RE: SH .18 in Volcano S30
if you got 5 tanks through it see what the manual says about head shims i know some have the head shimmed higher for the break in then you have to remove 1 or so to redo your squish
should have 2 .20 shims pull 1 and check your squish again (other wise it sounds like you burned up a piston and sleeve yet again temperature is a killer)
