RCU Forums - View Single Post - Pull-Pull Setup Question
Old 07-26-2003 | 04:46 AM
RCLIVIN
My Feedback: (46)
Default Pull-Pull Setup Question
you should have a slight amount of play in them, not loose But in the same breath not tight, depending on the servo's you are using, the servo may have a little slop "play" this will correct itself when you are flying, set neutral around the middle of slop & trim out on first flight, should be ok.
Gil
