RCU Forums - View Single Post - Crusader MK II, scratch
Old 08-14-2010 | 05:29 AM
volvospeed
Default RE: Crusader MK II, scratch
At the first Picture you see that i build everthing together as a test. I wanted to check the heigh with this suspension. Well 1cm to high. **** happens
First i screw and glow the axles together.
Here you see it better
Now, time to find out where the Probs are and how i can fix this.
Here...
and here
Allright, lets rock....
Cut out a little here
and here
Cut out a little from Panzer III Chains
Put Resin in here
Now its, strong enough
Inlay for Electricalstuff
New Optik for Idle Wheel
drilled a lot of holes into the tyres
Gearboxes
complette with inlay
