ORIGINAL: michael wood
Hi all I have a sport trainer that want to roll right I have the trim set all the way to the left and it is still not enough ive checked the tail and it is stright and the ailerons are even with the wing on drooping the rear stabilizer looks level so I am open to any help michael
Post a picture if you can. Here are a couple things to check.
Hold the wing and look down it from tip to tip. You are looking for a warp. Laying it on a flat surface and measuring the opposite wing front and back will also reveal any warps.
Also, balance the wing in the center and see if the right side drops. If it does, add weight to the left wing tip to balance.
I think more likely you will find a warp. These can usually be removed by twisting the wing in the opposite direction, and heating the covering to remove the wrinkles you will see.
Keep us posted.
