Ok, time to ask for help - ASP 52A-II needles settings
Hey guys.
I have an ASP 52A-II that I messed up the needle settings - too eager to play with it after buying the engine.
I have tried all the methods I can think of to reset the idle mixture screw - barrel open, needle fully in and backed out 3 turns (per Magnum manual); barrel open, needle fully backed out and screw in 3 turns, like larger four-strokes from Sanye.
The thing is, by using method one, the needle sist on the spray bar and wont let the carb close. Using method 2, I can't find the spot.
So... does any of you, kind soul, has a rightly set 52A to help me out with the idle screw?[sm=angel_smile.gif]
Thanks!
