RCU Forums - View Single Post - rolls right
Thread: rolls right
Old 08-15-2010 | 03:47 PM
ram3500-RCU's Avatar
ram3500-RCU
My Feedback: (221)
Default RE: rolls right
ORIGINAL: michael wood
cant move the linkage its a single servo as far as engine thrust it has right thrust and a little down thrust its a 60 size trainer and it has a 60 on it i noticed a little slop in the ailerons so i might go with duel sevros iam thinking that the slop is the problem when trimming cause if i trim it to the left the slop in the ailerons the wind force is pushing the ailerons down and not holding the trim setting what do you think michael
Where I meant for you to move the connection is on the aileron horns. This should be possible no matter how many servos are used. Slop is most definitely not good in any connection. This slop may be from the sheaths (outer tubes) moving. You may try gluing them where they exit the wings at both ends.
