ORIGINAL: michael wood
cant move the linkage its a single servo as far as engine thrust it has right thrust and a little down thrust its a 60 size trainer and it has a 60 on it i noticed a little slop in the ailerons so i might go with duel sevros iam thinking that the slop is the problem when trimming cause if i trim it to the left the slop in the ailerons the wind force is pushing the ailerons down and not holding the trim setting what do you think michael
You can't make an adjustment by turing a threaded connector on either end in or out? That might be a problem as even with single servo ailerons yu have to be able to set the neutral point independantly. Usuallt with a threaded clevis at one end.
