RE: New Four Stroke With Engine Knock
In their queste for ever more power, the compression ratio went up and up, until engines started to throw props because of pre-ignition of the charge. If you want a sweet running engine, either use a colder plug, add some 3% acetone to the fuel, or reduce compression ratio. Adding some water to the fuel also helps. This added water however spoils the brew quickly, so use up that fuel the same day!
