RCU Forums - View Single Post - New Four Stroke With Engine Knock
Old 08-16-2010 | 03:04 PM
R-Duhb
Default RE: New Four Stroke With Engine Knock
<span style="font-size: small">Thanks for the quick response!!!
Ok, I'll back off the needle valve a bit. I was concerned because O.S. FS91 doesn't do it. Ya gotta love the sound of a four-stroke.
In regards to the prop being thrown -The higher RPMs from a lean mixture will cause the prop nut to loosen? I'll be sure the tighten it as much as possible.
Thanks again!!</span>
