RCU Forums - View Single Post - New Four Stroke With Engine Knock
Old 08-16-2010 | 03:10 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: New Four Stroke With Engine Knock
No, the lean mixture will cause the mixture to detonate before the piston reaches the top (that's the knocking sound you're hearing). When you get too lean, the exploding mixture will stop the piston before it gets to the top and push it back down (a backfire). The sudden reversal of the engine is what is throwing the prop - it will also ruin the engine if it happens too much
