ORIGINAL: R-Duhb
.........I've tightened the spinner down to the point where outer ring of the spinner is bitting into the prop. I actually think I can get it even tighter, but I'm not sure how tight is too tight.
If you are using a wood propeller, and you are crushing the wood, then it is too tight.
