ORIGINAL: MichealMayberry
Michel- Ideally you want to keep the antenna's away from the electronics but I've done allot of testing/flying with the antenna(s) in the worst possible places with zero issues. As long as you get a good range check at all angles then you should be fine, especially using two antenna's.
BTW... Nice bird!
Mike.
