piston-ring replacement
Hi Dave. With a case brain drift I forgot the whole point was that you wanted to replace the ring. Anyway if you decide you need to you have the info. Did anyone mention to make sure the rod is put back in facing the same way? There is generally a chamfer in the front of the big hole to accommodate a radius on the pin. Is the power down on your engine?
