RE: nose up test
You are listening for the engine leaning out. With most standard fuel set ups, when you hold the nose up the engine will lean out. What you want is the max safe lean condition with the nose up and the engine running good in straight and level position. So if your plane is known to lean out a bunch, you really want to set the mixture with the nose up.
