RCU Forums - View Single Post - How To Build RC Jet Turbine Exhaust Tubes
Old 08-18-2010 | 02:50 PM
LN-JET's Avatar
LN-JET
Default RE: How To Build RC Jet Turbine Exhaust Tubes
I have made one tube so far, and so far I am very happy with it. It is the augmenting type, and I made it from .008" 304 from McMasterCarr.
Bellmouths: I once found a formula that said the radius should be internal dia/5. This is what I used, and the proportions seem good. Bellmouth was spun over a mdf plug in the lathe. I use full length lithoplate aluminum outer duct, 4mm spacing at the rear, and 6mm extension beyound the inner duct. I am running a JG100 engine, so the dimensions should be ok with 120 class turbines.
Lars
ID:	1486173   Click image for larger version
ID:	1486174   Click image for larger version
